[postgis-devel] 1.3.6 build failures
Kevin Neufeld kneufeld at refractions.net
Thu May 7 15:12:46 PDT 2009
That's "*couldn't* locate the postgresql jar".
Kevin Neufeld wrote:
> If I read your log correctly, it looks like the JDBC ant script failed
> since it could locate the postgresql jar  (A few lines up indicate that
> your "rpm -ql postgresql-jdbc" line failed to retrieve the package).
> -- Kevin
> Devrim GÜNDÜZ wrote:
>> Hi,
>> I just got these on Fedora build servers:
>> This is Fedora 10:
>> http://koji.fedoraproject.org/koji/getfile?taskID=1341515&name=build.log
>> Some related pre-logs:
>> http://koji.fedoraproject.org/koji/getfile?taskID=1341515&name=root.log
>> http://koji.fedoraproject.org/koji/getfile?taskID=1341515&name=state.log
>> This is Fedora-9:
>> http://koji.fedoraproject.org/koji/getfile?taskID=1341374&name=build.log
>> ..and related pre-logs:
>> http://koji.fedoraproject.org/koji/getfile?taskID=1341374&name=root.log
>> http://koji.fedoraproject.org/koji/getfile?taskID=1341374&name=state.log
>> What could the reason be? Package was built successfully on Fedora 11
>> and 12.
>> Regards,
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
