[postgis-devel] [WKT Raster] Regular blocking and null extent
Mateusz Loskot Mateusz.Loskot at cadcorp.com
Fri May 8 06:55:48 PDT 2009
Would like to clarify the regular blocking parts of the specification [1].
[1] http://trac.osgeo.org/postgis/wiki/WKTRaster/SpecificationWorking01
The extent field of RASTER_COLUMNS table is specified as:
"a polygon geometry containing all raster tiles, or NULL if predefined
bounds are not known. For "regular_blocking" cases this geometry will be
a simple rectangle. In other cases it might be an irregular polygon."
Shouldn't "will be" read "must be"?
Later in the specification:
"If the regular_blocking field is true
5. The extent field must be a simple rectangle (non-rotated)."
So, point 5 defines following assumptions:
* for regular_blocking, non-NULL extent must be specified
and
* specified extent must be non-rotated rectangle.
Certainly, if regular blocking coverage is empty, dimensions of extent
rectangle are equal to Zero. 0
Is that correct?
Shall we allow generation of regular blocking tables
from non-georeferenced datasets reported by GDAL as follows:
$ gdalinfo chessboard-64x64.tif
Driver: GTiff/GeoTIFF
Files: chessboard-64x64.tif
Size is 64, 64
Coordinate System is `'
Metadata:
  TIFFTAG_DOCUMENTNAME=/home/mloskot/data/test/sample/chessboard-64x64.tif
  TIFFTAG_IMAGEDESCRIPTION=Sample 4-fields greyscale chessboard
  TIFFTAG_XRESOLUTION=72
  TIFFTAG_YRESOLUTION=72
  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,   64.0)
Upper Right (   64.0,    0.0)
Lower Right (   64.0,   64.0)
Center      (   32.0,   32.0)
Band 1 Block=64x64 Type=Byte, ColorInterp=Gray
and assume pixelsize_x = 1 and pixelsize_y = -1 ?
Best regards,
Mateusz Loskot
Senior Programmer, Cadcorp
http://www.cadcorp.com
