[postgis-devel] wktraster versioning
Kevin Neufeld kneufeld at refractions.net
Tue May 26 11:57:59 PDT 2009
Just a quick note to the wktraster folks,
The PostGIS website contains links to the Raster project and tarball.  The name of the links and tarball are
automatically generated by using the version info found in http://svn.osgeo.org/postgis/spike/wktraster/Version.config.
Currently, the wktraster version is 0.0.0.  If this is not correct (ie. the wiki seems to indicate it might be 0.1.6)
then someone might want to update the Version.config file.
Cheers,
Kevin
