[postgis-devel] wktraster versioning
Kevin Neufeld kneufeld at refractions.net
Wed May 27 13:31:10 PDT 2009
It's actually the micro release number
http://svn.osgeo.org/postgis/trunk/Version.config
--Kevin
Pierre Racine wrote:
> Thanks Kevin,
> How is "SVN" added after the PostGIS version number? We should do the
> same to indicate it is the in-development version.
> Pierre
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-
>> bounces at postgis.refractions.net] On Behalf Of Kevin Neufeld
>> Sent: 26 mai 2009 14:58
>> To: PostGIS Development Discussion
>> Subject: [postgis-devel] wktraster versioning
>> Just a quick note to the wktraster folks,
>> The PostGIS website contains links to the Raster project and tarball.
> The name of the links and
>> tarball are
>> automatically generated by using the version info found in
>> http://svn.osgeo.org/postgis/spike/wktraster/Version.config.
>> Currently, the wktraster version is 0.0.0.  If this is not correct (ie.
> the wiki seems to indicate it
>> might be 0.1.6)
>> then someone might want to update the Version.config file.
>> Cheers,
>> Kevin
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
