[postgis-devel] Registering geometry columns
Kevin Neufeld kneufeld at refractions.net
Fri May 29 10:23:16 PDT 2009
That already exists.
Populate_Geometry_Columns() in trunk does just that.
Oh to be a dream fulfiller. :)
I just thinking to simply the user's perspective on the PostGIS metadata.
You're right, there are far too many management functions already.
-- Kevin
Paul Ramsey wrote:
> We have so so many geometry_columns management functions now. How
> about one function to rule them all. No arguments, it just
> (a) goes through geometry columns and makes sure every entry in fact exists
> (b) goes through the system tables and inserts every possible geometry
> column, both views and tables
> That's my dream.
> P
> On Fri, May 29, 2009 at 10:06 AM, Kevin Neufeld
> <kneufeld at refractions.net> wrote:
>> Thinking about the recent question on users, I think Piotr was just confused
>> about the functionality of AddGeometryColumn.  I think he was looking for
>> something that would simply register (or add) his view with geometry_columns
>> ... which got me thinking that there really isn't a clear way for users to
>> register/deregister their tables tables/views with PostGIS.
>> Sure we have DropGeometryColumn and friends, but these will actually drop
>> the geometry column or table ... not just remove a row or two from the
>> geometry_columns table.
>> If a user wants to register a view with PostGIS, do they really need to know
>> the internal make up of geometry_columns and manually insert and delete rows
>> from the PostGIS metadata?
>> Populate_Geometry_Columns(oid) that I wrote a while ago does abstract the
>> registering bit for either tables or views, but there is nothing available
>> to deregister a table or view.
>> Would it make sense to add a few new management functions to PostGIS?
>> RegisterRelation(oid)
>> RegisterColumn(rel oid, column oid)
>> DeRegisterRelation(oid)     or UnRegisterRelation
>> DeRegisterColumn(rel oid, column oid)
>> Well, those could be the implementation functions that we can wrap with any
>> number of possible APIs...
>> RegisterTable(tablename text)
>> RegisterTable(schema text, tablename text)
>> RegisterView(tablename text)
>> RegisterView(schema text, tablename text)
>> RegisterGeometryColumn(relname text, columnname text)
>> RegisterGeometryColumn(schemaname text, relname text, columnname text)
>> DeRegister...
>> Am I thinking too ESRI-ish?  PostGIS is supposed to be easy to use.  Does
>> this make thing more clear or does it muddy the waters?
>> -- Kevin
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
