[postgis-devel] Registering geometry columns
Paul Ramsey pramsey at cleverelephant.ca
Fri May 29 10:51:57 PDT 2009
Excellent! Now make it do views too!
On Fri, May 29, 2009 at 10:23 AM, Kevin Neufeld
<kneufeld at refractions.net> wrote:
> That already exists.
> Populate_Geometry_Columns() in trunk does just that.
> Oh to be a dream fulfiller. :)
> I just thinking to simply the user's perspective on the PostGIS metadata.
> You're right, there are far too many management functions already.
> -- Kevin
> Paul Ramsey wrote:
>> We have so so many geometry_columns management functions now. How
>> about one function to rule them all. No arguments, it just
>> (a) goes through geometry columns and makes sure every entry in fact
>> exists
>> (b) goes through the system tables and inserts every possible geometry
>> column, both views and tables
>> That's my dream.
>> P
>> On Fri, May 29, 2009 at 10:06 AM, Kevin Neufeld
>>> Thinking about the recent question on users, I think Piotr was just
>>> confused
>>> about the functionality of AddGeometryColumn.  I think he was looking for
>>> something that would simply register (or add) his view with
>>> geometry_columns
>>> ... which got me thinking that there really isn't a clear way for users
>>> to
>>> register/deregister their tables tables/views with PostGIS.
>>> Sure we have DropGeometryColumn and friends, but these will actually drop
>>> the geometry column or table ... not just remove a row or two from the
>>> geometry_columns table.
>>> If a user wants to register a view with PostGIS, do they really need to
>>> know
>>> the internal make up of geometry_columns and manually insert and delete
>>> rows
>>> from the PostGIS metadata?
>>> Populate_Geometry_Columns(oid) that I wrote a while ago does abstract the
>>> registering bit for either tables or views, but there is nothing
>>> available
>>> to deregister a table or view.
>>> Would it make sense to add a few new management functions to PostGIS?
>>> RegisterRelation(oid)
>>> RegisterColumn(rel oid, column oid)
>>> DeRegisterRelation(oid)     or UnRegisterRelation
>>> DeRegisterColumn(rel oid, column oid)
>>> Well, those could be the implementation functions that we can wrap with
>>> any
>>> number of possible APIs...
>>> RegisterTable(tablename text)
>>> RegisterTable(schema text, tablename text)
>>> RegisterView(tablename text)
>>> RegisterView(schema text, tablename text)
>>> RegisterGeometryColumn(relname text, columnname text)
>>> RegisterGeometryColumn(schemaname text, relname text, columnname text)
>>> DeRegister...
>>> Am I thinking too ESRI-ish?  PostGIS is supposed to be easy to use.  Does
>>> this make thing more clear or does it muddy the waters?
>>> -- Kevin
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
