[postgis-devel] [PostGIS] #280: in_gml regression test fails
PostGIS trac at osgeo.org
Mon Nov 2 03:36:52 PST 2009
  Reporter:  mloskot     |       Owner:  colivier
      Type:  defect      |      Status:  closed
  Priority:  medium      |   Milestone:  postgis 1.5.0
 Component:  postgis     |     Version:  trunk
Resolution:  worksforme  |    Keywords:
Changes (by mloskot):
  * status:  new => closed
  * resolution:  => worksforme
Comment:
 Yes, you are right. This problem is caused by the Hausdorff test.
 Disabling the Hausdorff makes the regression tests passing:
  regress_ogc_prep. ok
  regress_buffer_params. ok
  in_gml. ok
 Run tests: 44
 Failed: 0
 I'm closing this ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/280#comment:7>
