[postgis-devel] [PostGIS] #288: ST_AsBinary should return SQL/MM WKB
PostGIS trac at osgeo.org
Fri Nov 6 09:19:12 PST 2009
 Reporter:  pramsey  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  postgis 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Moving to SQL/MM, the AsBinary conversion should now support higher
 dimensional types, using the type numbers as specified in SQL/MM.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/288>
