[postgis-devel] [PostGIS] #242: Go back to having different scripts version from postgis lib version
trac at osgeo.org
Fri Nov 6 23:57:51 PST 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: postgis 1.4.1
Component: postgis | Version:
Resolution: | Keywords:
Changes (by robe):
* status: closed => reopened
* resolution: wontfix =>
Comment:
Paul,
Thanks -- I took a quick look at this script and it looks promising and an
elegant solution to the problem. Good solution though haven't figured out
yet how this would tie in with our build of the postgis.sql file (unless
we just amend our how to release to include this perl check step and keep
manual for now)
So our scripts version numbers would now be
POSTGIS_MAJOR.POSTGIS_MINOR.SVNVERSION
e.g.
1.5.(svnversion since last script changed output from perl script)
So I take it the challenge is to
In our postgis_scripts_released() function -- some how stuff this perl
gotten revision number in there.
In our postgis_scripts_installed sql function -- some how stuff this perl
Or just take the manual way for now and hardcode it accordingly by
manually running the perl script to get the number. Would be nice if we
could automate it though.
So I guess this means I can reopen this?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/242#comment:7>
