[postgis-devel] [PostGIS] #219: Run 'make check' without needing 'make install' first
PostGIS trac at osgeo.org
Sun Nov 8 02:49:11 PST 2009
  Reporter:  pramsey      |       Owner:  pramsey
      Type:  enhancement  |      Status:  reopened
  Priority:  medium       |   Milestone:  postgis 1.5.0
 Component:  postgis      |     Version:  trunk
Resolution:               |    Keywords:
Comment (by jorgearevalo):
 Replying to [comment:10 mloskot]:
 > Just keeping it up, ''make check'' is still failing (r4643):
 > loskot at vb-ubuntu910-x64:~/dev/postgis/_svn/trunk$ head -n4
 /tmp/pgis_reg_6641/regress_log
 > BEGIN
 > psql:postgis.sql:53: NOTICE:  type "spheroid" is not yet defined
 > DETAIL:  Creating a shell type definition.
 > psql:postgis.sql:53: ERROR:  could not access file
 "/home/mloskot/dev/postgis/_svn/trunk/regress/../postgis/libpostgis-1.5":
 >   No such file or directory
 I'm having the same problem just now.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/219#comment:12>
