[postgis-devel] [PostGIS] #264: CUnit geography suite failures
PostGIS trac at osgeo.org
Mon Nov 9 09:17:54 PST 2009
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  postgis 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by pramsey):
 Hrm, hrm, sure you're upgraded to the latest? Just a hopeful question, if
 not this is a very ugly problem, because a tolerance that is loose enough
 to catch double equality in MinGW is going to be loose enough to give
 wrong false positives on other platforms.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/264#comment:7>
