[postgis-devel] [PostGIS] #264: CUnit geography suite failures
PostGIS trac at osgeo.org
Mon Nov 9 19:13:20 PST 2009
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  postgis 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by robe):
 Its all above but here it is again.
 For the MingW -- gcc.exe (GCC) 4.4.0  (note the other MingW I normally use
 ((GCC) 3.4.5) only had 2 errors before and you fixed those which also
 knocked of 2 of the 4 in the newer GCCs)
 Open SUSE 11 -- 4.3.1 20080507 (prerelease) [gcc-4_3-branch revision
 135036]
Ticket URL: <http://trac.osgeo.org/postgis/ticket/264#comment:10>
