[postgis-devel] Multi-Lingual Docs
Olivier Courtin olivier.courtin at oslandia.com
Tue Nov 10 00:44:16 PST 2009
On Oct 24, 2009, at 2:35 AM, Paul Ramsey wrote:
> This project seems to provide a template for doing multi-lingual
> docbook in unified way, with a minimal amount of duplication (in
> particular, we want to avoid duplicating things like the diagram
> generation and the SQL code examples and so on across translations).
> Thoughts?
Related to PgDay Europe (previous week) we found several
volunteers to begin a FR translate initiative based on the new
doc
Some technical thoughts:
  - It could be a good think to split the big reference.xml file into
    smaller ones to be able to parrallelize translation work easily
    (one file per familly function as Administration functions,
     geometry constructors...)
  - I suggest also to use XML entities as often as we can to factorize
some
    redundant Docbook code (SQL/MM compatibility, or 3D enabled for
instance)
HTH,
Olivier
