[postgis-devel] Multi-Lingual Docs
George Silva georger.silva at gmail.com
Tue Nov 10 14:01:15 PST 2009
I'm up for a new pt translation. I just need to learn how to use/or know
(windows) tools that will help to do the job.
Can anyone provide more info on that? I know it's "just" a structure, but
here's the question: can i translate it using Eclipse? If so, where do i
start?
Thanks
George
On Tue, Nov 10, 2009 at 2:53 PM, Olivier Courtin <
olivier.courtin at oslandia.com> wrote:
> On Nov 10, 2009, at 5:45 PM, Kevin Neufeld wrote:
> Kevin,
>  - I suggest also to use XML entities as often as we can to factorize some
>>>  redundant Docbook code (SQL/MM compatibility, or 3D enabled for
>>> instance)
>> Either that or use ENTITY variables as in top of postgis.xml for common
>> text.
> Yeap we talk about the same thing :)
> Olivier
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
George R. C. Silva
Desenvolvimento em GIS
www.sextantegeo2.blogspot.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091110/8635270a/attachment.html>
