[postgis-devel] [PostGIS] #297: Implement ST_AsPolygon function for raster
PostGIS trac at osgeo.org
Tue Nov 10 14:51:41 PST 2009
 Reporter:  mloskot    |       Owner:  pracine
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  wktraster 0.1.6
Component:  wktraster  |     Version:
 Keywords:             |
 Function ST_AsPolygon is part of [wiki:WKTRaster/SpecificationWorking01
 Objective 0.1.6e] and shall be implemented:
 ST_AsPolygon(raster) -> polygon geometry set
 This algorithm is very useful since it ensure that
 ST_AsRaster(ST_AsPolygon(raster)) should returns the same raster as the
 original (because it is based on the centroid of the pixel).
 Open questions:
  * Pierre: Can we directly use the GDAL function by copying the raster
 data into a GDAL structure or should we just copy/adapt the algorythm?
 References:
 [http://trac.osgeo.org/gdal/browser/trunk/gdal/alg/polygonize.cpp?rev=16328
 Raster to Polygon Converter] implemented in GDAL
Ticket URL: <http://trac.osgeo.org/postgis/ticket/297>
