[postgis-devel] Three fixes to pgsql2shp
Kris Jurka books at ejurka.com
Thu Nov 12 03:16:18 PST 2009
Attached are three fixes to pgsql2shp.
1) 001-know-more-type-size.patch, Improve the exporter's knowledge of pg
type sizes to fix timestamp and include timestamptz, time, timetz, and
uuid.  I was dumping a timestamptz column and it decided it was only 8
bytes long (the internal size, not the text size, see #3) so all of my
timestamps were truncated.
2) 002-no-implicit-casts-with-83.patch, Starting with postgresql 8.3
implicit casts to text have been removed.  Therefore the call to
octet_length will fail.
3) 003-attlen-is-useless.patch.  pg_attribute.attlen is the internal
storage size of the type, which has nothing to do with the exported size
in text format.  If we don't know anything about the type by oid, our
only option is to do a brute force search through the table.
Below are test cases showing the problems that are fixed by these
patches.  This was tested on postgresql 8.3.7 running postgis 1.3, but
these patches were developed against SVN trunk as they are completely a
client side issue and are really unrelated to geometry handling.
CREATE TABLE t (a timestamptz, b xml, c oid, d geometry);
     (now(), '<a>hi</a>', 12345678, geomfromewkt('POINT(3 4)'));
1) Truncated timestamptz column:
$ pgsql2shp -ftypetest testdb 'SELECT a, d FROM t'
$ dbview typetest.dbf
A          : 2009-11-
2) Can't find length of xml type:
$ pgsql2shp -ftypetest testdb 'SELECT b, d FROM t'
Preparing table for user query... Done.
Initializing... Querying for maximum field length: ERROR:  function
octet_length(xml) does not exist
LINE 1: select max(octet_length("b")) from "__pgsql2shp9894_tmp_tabl...
HINT:  No function matches the given name and argument types. You might
need to add explicit type casts.
3) Wrong length for unknown fixed size type results in a truncated value:
$ pgsql2shp -ftypetest testdb 'SELECT c, d FROM t'
C          : 1234
So with all of these patches applied we get:
$ pgsql2shp -ftypetest testdb 'SELECT a, b, c, d FROM t'
A          : 2009-11-12 03:02:28.262377-08
B          : <a>hi</a>
C          : 12345678
Kris Jurka
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091112/f71479ec/attachment.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091112/f71479ec/attachment-0001.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091112/f71479ec/attachment-0002.bin>
