[postgis-devel] Upgrades
Paragon Corporation lr at pcorp.us
Thu Nov 12 16:41:07 PST 2009
Okay good.  Those were the ones I was really concerned about.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Thursday, November 12, 2009 4:40 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Upgrades
Well, in that case I am going to proceed with what I consider the least
painful approach and build 4 upgrade scripts
postgis_upgrade_1.5_minor.sql
postgis_upgrade_1.4_to_1.5.sql
postgis_upgrade_1.3_to_1.5.sql
postgis_upgrade_1.2_to_1.5.sql
I'll also be adding a postgis_removed.sql.in.c file that includes old
functions that are no longer available in 1.5 and can be DROP FUNCTION IF
EXISTS.
P.
PS - In case you missed a commit from this morning, I put back in the st_
functions that back operators and types, since those are not in-place
updatable.
On Thu, Nov 12, 2009 at 1:15 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Paul,
> hmm -- I don't like that policy because it results in broken installs.
> There are some errors you can't ignore and shouldn't.
> Even more so now than before.  As I said -- with the lets ignore the
> errors, you'll have people with bits of there PostGIS 1.5 pointing at
> bits of 1.4 and 1.3.  Not good.  Keep in mind all these will sort of
> work since we can now have multiple PostGIS versions running on a
PostgreSQL server instance.
> I also don't always like the dump restore especially for large
> databases, and that's really the only case where you can safely ignore the
errors.
> I have for example a client that has a 800 GB database.  There is no
> way I'm going to sell them on a dump restore - especially since they
> just moved into their new brank spanking server.  Yes I can work
> around it and remove the remnants and stuff, but most people can not.
> Thanks,
> Regina
> Paul Ramsey
> Sent: Thursday, November 12, 2009 3:29 PM
> Subject: [postgis-devel] Upgrades
> I have spend several hours thinking about this stuff, reviewing my old
> world and Regina's code in here
> (http://trac.osgeo.org/postgis/attachment/ticket/202), and I've
> decided I hate it all.
> The old way, generating a postgis_upgrade.sql file from the
> postgis.sql file is a beauty, I love it, but it conditional stuff gets
> really ugly and since
> 1.3 we've added conditional stuff: the upgrade to 1.4 required two new
> types, which you would want defined for 1.3 -> 1.4.0 but ignored for
> 1.4.0
> -> 1.4.1.
> And the upgrade to 1.5 just piles onto that a couple new types a pile
> of operators and a couple operator classes, all of which would require
> conditional handling to add them for upgrades from previous major
> versions but ignore them for upgrades from minor versions.
> And this got me thinking about upgrades in general, and how our
> current "best" upgrade advice is not actually any fancy script process but
simply:
> - create a new database with the new version of postgis in it
> - dump from the old database and restore into the new one
> - ignore the errors
> Works pretty good. And all that conditional mess in the upgrade
> scripts could similarly be dropped if the upgrade process was
> - run the upgrade script
> - ignore the errors
> So. Here I am. Mark, I know, favors some kind of fragment approach,
> and I thought about that a good while too but never came up with a
> scheme that wasn't going to be very very hard to maintain. (It took me
> half-an-hour just to remember the issues involved in upgrade. If I
> needed to keep the issues in mind every time I altered a function
> definition in the SQL files, that could be a bit much.)
> So my current suggestion is "worse is better". Move to an "ignore the
> errors" upgrade policy and fully document that.
> P.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
