[postgis-devel] [PostGIS] #303: Test results are language dependent
PostGIS trac at osgeo.org
Fri Nov 13 09:18:48 PST 2009
  Reporter:  jorgearevalo  |       Owner:  pramsey
      Type:  enhancement   |      Status:  new
  Priority:  low           |   Milestone:  postgis 1.5.0
 Component:  postgis       |     Version:  trunk
Resolution:                |    Keywords:  tests
Comment (by jorgearevalo):
 Sure thing!
 $ export LANG=C[[BR]]
 $ make check[[BR]]
 (...)[[BR]]
 Run tests: 46[[BR]]
 Failed: 0[[BR]]
 $ export LANG=es_ES.UTF-8[[BR]]
 I don't know if it's the best way, but it works for me. Maybe I should
 detect the previous value of LANG and then restore it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/303#comment:3>
