[postgis-devel] [PostGIS] #306: gdal2wktraster: error generating ov tables names
PostGIS trac at osgeo.org
Sat Nov 14 11:00:41 PST 2009
 Reporter:  jorgearevalo    |       Owner:  jorgearevalo
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  wktraster 0.1.6
Component:  wktraster       |     Version:  trunk
 Keywords:  gdal2wktraster  |
 When you specify the input table name as "-t schema.table", the "create
 table" sql code for overviews (level > 1) is generated with a bad table
 name. This script fixes the problem.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/306>
