[postgis-devel] [PostGIS] #306: gdal2wktraster: error generating ov tables names
trac at osgeo.org
Sat Nov 14 18:08:52 PST 2009
Reporter: jorgearevalo | Owner: jorgearevalo
Type: defect | Status: closed
Priority: medium | Milestone: wktraster 0.1.6
Component: wktraster | Version: trunk
Resolution: fixed | Keywords: gdal2wktraster
Changes (by jorgearevalo):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [ticket:306 jorgearevalo]:
> When you specify the input table name as "-t schema.table", the "create
table" sql code for overviews (level > 1) is generated with a bad table
name. This script fixes the problem.
Patch applied and code commited.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/306#comment:1>
