[postgis-devel] [PostGIS] #303: Test results are language dependent
PostGIS trac at osgeo.org
Sun Nov 15 11:32:32 PST 2009
  Reporter:  jorgearevalo  |       Owner:  pramsey
      Type:  enhancement   |      Status:  new
  Priority:  low           |   Milestone:  postgis 1.5.0
 Component:  postgis       |     Version:  trunk
Resolution:                |    Keywords:  tests
Comment (by pramsey):
 I added in a 'C' setting in run_test, can you check that trunk at r4815
 works?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/303#comment:5>
