[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
PostGIS trac at osgeo.org
Sun Nov 15 14:22:17 PST 2009
  Reporter:  robe     |       Owner:  colivier
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  postgis 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by robe):
 Olivier,
 I haven't tested against 3.1.1 in a while.  Been doing all my testing
 against GEOS 3.2.0rc1 and GEOS 3.2SVN.  Its kind of cruel to give people
 GEOS 3.1 with 1.5 anyway since the fast buffering, new buffer features and
 hausdo... they would miss out on.
 From what I can tell from your screen -- it looks like you have some
 remnants of libgeos-3-2 in there (note the
 /usr/local/bin/libgeos-3-2-0.dll (or that justa  bad message in the geos
 code.  Try using the GEOS 3.2 instead (note the changes you'll need to
 hack in your mingw I noted) to get geos 3.2 to compile.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:10>
