[postgis-devel] [PostGIS] #219: Run 'make check' without needing 'make install' first
PostGIS trac at osgeo.org
Mon Nov 16 13:36:27 PST 2009
  Reporter:  pramsey      |       Owner:  pramsey
      Type:  enhancement  |      Status:  reopened
  Priority:  medium       |   Milestone:  postgis 1.5.0
 Component:  postgis      |     Version:  trunk
Resolution:               |    Keywords:
Comment (by pramsey):
 Between 8.3 and 8.4 PgSQL changed the name of the library from
 libpostgis.so to postgis.so, hence the problem.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/219#comment:13>
