[postgis-devel] postgis-1.5.sql
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Nov 17 06:35:35 PST 2009
Paragon Corporation wrote:
> Since no one said anything. Let me make it clear
> 1) I like versionning the folder
> BUT
> 2) I HATE the idea of versioning the sql files, because we have too many and
> with the proliferation of upgrade script files, the situation only gets
> worse and annoying.
> Having to see all the files in the same folder regardless of how they are
> versioned for the different versions of postgis I would find terribly
> annoying.
> I think its an advantage to be able to run different versions of PostGIS on
> the same box especially if you are a consultant or doing dev work, but I
> just don't like seeing all those files in the same folder
For the record, I would definitely prefer the use of folders for this.
However, PGXS currently doesn't have the ability to do this
automatically and it would be quite a bit of a hack to do this in its
current form :(
I'd be quite happy with an extra PGXS parameter such as MODULEDIR which
defaults to the same value as MODULE_big. Then during a "make install",
PGXS would drop documentation into $(docdir)/$MODULEDIR and DATA_built
files into $(sharedir)/$MODULEDIR. Bonus points would allow entire
directories as well as files to be installed into these locations during
"make install" too.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
