[postgis-devel] Distance / Shp2Pgsql
Nicklas Avén
nicklas.aven at jordogskog.no
Wed Nov 18 01:04:44 PST 2009
Hallo I have ran into troubles I can't handle with the code, or at least it will need time I don't have. Regina also found a bug in the sub-geometry handling which I don't see what it is, at once (shouldn't be to difficult to find though) Because of this I think I better let out this subgeometry handling for this version and focus on the faster algoritm and new functions. If I remove this "preprocessing" with subgeometries and just implement those suggestions you gave Paul I think I can get it working in a day or two and maybe after testing it can go to trunk after weekend, when I will get some time to work on it. Then I hope to get the subgeometry handling working to some later release. Is that ok? The problem I have in the code I think is very strange. I cannot see the logic in the crashes. If I for instance force an iteration to only iterate once it all works, but if I let it go a second round it doesn't even complete the first round. I have had several situations where !
I do an edit late in the code which causes a crash early in the code. That makes it very hard to see what's happening. I guess I have made some fundamental thing totaly wrong in the bginning of the code causing it all to be very instable. /Nicklas
2009-11-18 Paul Ramsey wrote:
Niklas, Mark,
>The two largest items left on the 1.5 docket are the new distance work
>and the upgrades to shp2pgsql. Can you give me ETAs on those? I'd like
>to start the 1.5 train towards the station...
>P.
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091118/e595a5fc/attachment.html>
