[postgis-devel] [PostGIS] #313: Remove reference.xml and autogenerate from new separate xml docos
PostGIS trac at osgeo.org
Wed Nov 18 05:56:29 PST 2009
  Reporter:  robe     |       Owner:  colivier
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by robe):
 I was actually thinking it was simple -- just have as part of the make
 process
 reference_* target -> reference.xml
 (probably would be easier if we named our reference files so they are
 directory wise alphabetical that way I imagine  -- you could come up with
 a hack to -- pick up all the files that start with reference_ and if we
 add more we just name them so they are always in alphabetical order the
 way we want them to appear.
 Kevin is already doing that to stitch the new sections we autogenerate
 using the .xsl files -> to generate -- postgis.xml as I recall.
 But heck what do I know.  I only work with conceptual models not real
 code. :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/313#comment:2>
