[postgis-devel] [PostGIS] #313: Remove reference.xml and autogenerate from new separate xml docos
trac at osgeo.org
Wed Nov 18 07:29:04 PST 2009
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by colivier):
Well that's not that simple too, that's also was my first try ;)
As we need also to load new entities (and so postgis.xml), and if we do
that (use postgis.xml rather than reference_*), we need to modify xsl (at
least as long as we cannot define entity in other place than DocBook root
node)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/313#comment:3>
