[postgis-devel] geography_columns + geometry_columns
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Thu Nov 19 03:04:44 PST 2009
Paul Ramsey wrote:
> This is more of a 2.0 idea, since ideally it depends on having typmod support everywhere, but I am trying to think if there's any reason not to unify geometry_columns and geography_columns into a single view (probably called geometry_columns, but with an extra column to flag type differences for apps that care).
> In general naive applications that don't understand geography can still treat is at geometry-with-epsg-4326 and get perfectly respectable results, and that's all the metadata table is used for, so... any reason not to add this as a 2.0 task?
> P
For 1.5, I'm definitely quite happy leaving them as separate concepts
since it's then easy for applications which want to understand geography
to look inside the geography_columns view as required, and those that
don't to ignore it. I think this is slightly more relevant now because
the geography and geometry types have different binary representations.
I think for 2.0 we should raise a proposal through OGC (and maybe the
PostgreSQL chaps can get us to talking to the SQL/MM committee) so then
at least we can ensure in the long run that everyone will be taking the
same approach.
Anyone here a member of the OGC?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
