[postgis-devel] [PostGIS] #313: Remove reference.xml and autogenerate from new separate xml docos
trac at osgeo.org
Thu Nov 19 14:55:00 PST 2009
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by colivier):
I commit entities stuff as r4866.
I finally choose to slightly modify xsl files, because:
- XSL changes are in fact really small
- We keep the ability to validate with xmllint --valid postgis.xml
without having to play first with doc/Makefile
- I already have met sed portability issue, never met with xsl.
As a consequence gardentest xsl file must now been called with postgis.xml
rather than refence.xml file.
I keep the ticket open, till Kevin and Regina are Okay on this solution.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/313#comment:7>
