[postgis-devel] [PostGIS] #313: Remove reference.xml and autogenerate from new separate xml docos
PostGIS trac at osgeo.org
Fri Nov 20 04:12:50 PST 2009
  Reporter:  robe     |       Owner:  colivier
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Looks fine to me too. I see the new entries are showing in "What's new in
 1.5"
 Great job Olivier.  I looked at the way you did it and I like it.  I think
 this will also make it easier to integrate Mateusz suggestion about
 postgresql comments on types, because now we won't be limited to scanning
 just references section for postgresql help comments (can expand easily by
 adding in another chapter in your xsl filter).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/313#comment:9>
