[postgis-devel] Distance patch
Paul Ramsey pramsey at cleverelephant.ca
Sun Nov 22 09:20:25 PST 2009
On Sun, Nov 22, 2009 at 3:38 AM, Nicklas Avén
<nicklas.aven at jordogskog.no> wrote:
> Or should I put lwerror where the error occurs. As I understand it lwerror
> stops everything, so then the LW_TRUE, LW_FALSE thing will not be use for
> more than the uncatched cases.
It you're not going to recover from the error, put it where it happens.
