[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
PostGIS trac at osgeo.org
Tue Nov 24 05:30:19 PST 2009
  Reporter:  robe     |       Owner:  colivier
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by robe):
 Hmm I think I'm running mingw 5.04, though not sure that matters.  I did
 conclude its not the VC++ PG build, since it crashes under my mingw pg
 compiled version too.  Though it starts off with a gml namespace is not
 defined in the logs and then crashes.
 I'm going to try Mark's backtrace instructions next to narrow it down more
 once I get gdb loaded.
 Olivier -- can you attach your postgis dll and libxml dlls so I can test
 on my box to verify its not some other dependency I have and just isolated
 to those (or the libxml).  I'm guessing if I still have a crash with your
 working copy -- then its something else on my boxes I have installed
 causing the problem.
 Thanks,
 Regina
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:16>
