[postgis-devel] [PostGIS] #318: 900913->4326 Transform
PostGIS trac at osgeo.org
Wed Nov 25 10:17:02 PST 2009
 Reporter:  pramsey  |       Owner:  mcayland
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Originally reported on postgis-users against 1.3.6, strange results are
 also available on 1.5:
 geog=# select postgis_full_version();
  POSTGIS="1.5.0SVN" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August
 2008" USE_STATS (procs from 1.5 r4836 need upgrade)
 (1 row)
 geog=# SELECT
 ASTEXT(ST_Transform(ST_SetSRID(ST_Point(-633510.090428,7506727.67383),900913),4326));
                   astext
  POINT(-5.69091796875412 55.7394816986905)
 (1 row)
 geog=# SELECT
 ASTEXT(ST_Transform(ST_SetSRID(ST_Point(-305748.113141,7834489.65112),900913),4326));
 ERROR:  transform: couldn't project point (-305748 7.83449e+06 0): failed
 to load NAD27-83 correction file (-38)
 HINT:  PostGIS was unable to transform the point because either no grid
 shift files were found, or the point does not lie within the range for
 which the grid shift is defined. Refer to the ST_Transform() section of
 the PostGIS manual for details on how to configure PostGIS to alter this
 behaviour.
 geog=# SELECT
 ASTEXT(ST_Transform(ST_SetSRID(ST_Point(-305748.113141,7834489.65112),900913),4269));
                   astext
  POINT(-2.74658203125265 57.3620898624176)
 (1 row)
 geog=# SELECT
 ASTEXT(ST_Transform(ST_SetSRID(ST_Point(-305748.113141,7834489.65112),900913),4267));
                   astext
  POINT(-2.74658203125265 57.3620898615614)
 (1 row)
 Note that for some reason we get NAD27/83 grid failure in the 900913->4326
 case but *not* in the transforms into NAD83 and NAD27!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/318>
