[postgis-devel] [PostGIS] #320: Upgrade scripts PostGIS 1.4/1.5 need some work
PostGIS trac at osgeo.org
Thu Nov 26 08:30:11 PST 2009
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.4.2
Component:  postgis  |     Version:  trunk
 Keywords:           |
 I think the 1.4 has same issues.  I think maybe we should move the DROP IF
 EXISTS functions out of COMMIT; block or handle the dependencies
 correctly.
  I had to do that to get the upgrade to work.   For example I get this
 when upgrading my PostGIS 1.5
 ERROR:  cannot drop function geom_accum(geometry[],geometry) because other
 objects depend on it
 DETAIL:  function geomunion_old(geometry) depends on function
 HINT:  Use DROP ... CASCADE to drop the dependent objects too.
 ********** Error **********
 SQL state: 2BP01
 Detail: function geomunion_old(geometry) depends on function
 Hint: Use DROP ... CASCADE to drop the dependent objects too.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/320>
