[postgis-devel] Error compiling r4906: POSTGIS_LIBXML2_VERSION
Jorge Arévalo jorge.arevalo at gmail.com
Thu Nov 26 10:45:34 PST 2009
Forget it. You were right, of course :-). I'm working with geos-svn
and postgis-svn, and I executed autogen in the geos tree, not in
postgis tree.
I'm sorry
Thanks!
2009/11/26 Jorge Arévalo <jorge.arevalo at gmail.com>:
> Yes, I did it. Actually, I deleted the entire source tree and checkout
> it again. So, I execute ./autogen.sh and then ./configure and make.
> On Thu, Nov 26, 2009 at 7:25 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
>> Perhaps ./autogen.sh before the ./configure?
>>> Hello,
>>> I'm compiling PostGIS SVN r4906 (the last one just now) on Ubuntu
>>> 9.10, and I have this error executing "make":
>>> lwgeom_functions_basic.c: In function postgis_libxml_version:
>>> lwgeom_functions_basic.c:205: error: POSTGIS_LIBXML2_VERSION
>>> undeclared (first use in this function)
>>> lwgeom_functions_basic.c:205: error: (Each undeclared identifier is
>>> reported only once
>>> lwgeom_functions_basic.c:205: error: for each function it appears in.)
>>> xml2-config has been properly detected during configure. I can see
>>> POSTGIS_LIBXML2_VERSION is defined in <src>/postgis/sqldefines.h, and
>>> it has been added in the last revision of sqldefines.h.in file (this
>>> is, r4885).
>>> Attached is config.log, just in case. I executed "configure" without options.
>>> Any clues?
>>> Thanks in advance.
>>> Best regards,
>>> Jorge
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
