[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
PostGIS trac at osgeo.org
Sat Nov 28 02:08:44 PST 2009
  Reporter:  robe     |       Owner:  colivier
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by colivier):
 Regina,
 1)
 Libxml2:
 ./configure --prefix=/c/postgres
 # make
 # make install
 PostGIS:
 # ./configure \
       --prefix=/c/postgres \
       --with-pgconfig=/c/postgres/bin/pg_config \
       --with-geosconfig=/c/postgres/bin/geos-config \
       --with-projdir=/c/postgres
 # export PATH=/c/postgres/bin:$PATH
 # make clean
 # make
 # make install
 2) Libxml2 is released under MIT license, so not a problem to link/use it
 the way you want.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:22>
