[postgis-devel] trunk build errors during "make -C postgis"
Kevin Neufeld kneufeld at refractions.net
Mon Nov 30 09:05:41 PST 2009
Going through the buildbot's logs for the weekend I noticed this:
make -C postgis
make[1]: Entering directory `/var/home/buildbot/opt/hudson/jobs/PostGIS-trunk-build/workspace/src/postgis'
gcc -E -traditional-cpp postgis.sql.in.c | grep -v '^#' > postgis.sql.in
postgis.sql.in.c:3431: error: #if with no expression
postgis.sql.in.c:4506: error: #if with no expression
-- Kevin
