[postgis-devel] [PostGIS] #255: Geodetic point-in-polygon breaking case
Martin Davis mbdavis at refractions.net
Thu Oct 1 11:29:01 PDT 2009
Paul, can you post a test case which exhibits this behaviour?  As far as
I know, the JTS/GEOS algorithm handles this case fine.
>  Reporter:  pramsey  |       Owner:  pramsey
>      Type:  defect   |      Status:  new
>  Priority:  medium   |   Milestone:  postgis 1.5.0
> Component:  postgis  |     Version:  trunk
>  Keywords:           |
>  If the stab line used for point-in-polygon calculation intersects a
>  parallel edge on the way out of the polygon, it will trigger a double
>  count, and will end up returning the wrong result.
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
