[postgis-devel] [PostGIS] #253: Gist causes wrong result from ~=
PostGIS trac at osgeo.org
Fri Oct 2 04:45:50 PDT 2009
  Reporter:  nicklas  |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  postgis 1.5.0
 Component:  postgis  |     Version:  1.4.X
Resolution:           |    Keywords:
Comment (by mcayland):
 No, this is wrong as all indexable operators (which is all of the ones in
 the gist_geometry_ops class) only work on the bounding boxes of the
 geometries - remember that && is only a bounding box overlap. So ~= should
 return true if the bounding boxes are equal, regardless of whether or not
 the geometries are the same.
 ATB,
 Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/253#comment:8>
