[postgis-devel] [PostGIS] #257: Ability to cast from geography to geometry
PostGIS trac at osgeo.org
Sun Oct 4 15:24:44 PDT 2009
  Reporter:  robe         |       Owner:  pramsey
      Type:  enhancement  |      Status:  new
  Priority:  medium       |   Milestone:  postgis 1.5.0
 Component:  postgis      |     Version:
Resolution:               |    Keywords:
Old description:
> Perhaps I missed this -- but how does one CAST from geography to geometry
> without going thru ST_AsText
> I can do this  geography(somegeometry)
> but no equivalent geometry(somegeography)
> and when I do this:  a.the_geog::geometry
> I get this:
> cannot cast type geography to geometry
> Also by the way your tests are failing again.
> Suite: Geodetic Suite
>   Test: test_signum() ... passed
>   Test: test_gbox_from_spherical_coordinates() ... passed
>   Test: test_gserialized_get_gbox_geocentric() ... passed
>   Test: test_clairaut() ... passed
>   Test: test_edge_intersection() ... FAILED
>     1. cu_geodetic.c:353  - CU_ASSERT_EQUAL(rv,LW_TRUE)
>     2. cu_geodetic.c:361  - CU_ASSERT_EQUAL(rv,LW_TRUE)
>   Test: test_edge_distance_to_point() ... passed
>   Test: test_edge_distance_to_edge() ... passed
>   Test: test_lwgeom_distance_sphere() ... passed
New description:
 I get this:
Comment (by pramsey):
 I've removed the unrelated info from the ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/257#comment:1>
