[postgis-devel] Is ST_IsValid OGC or not OGC?
Kevin Neufeld kneufeld at refractions.net
Mon Oct 5 13:54:06 PDT 2009
Hi Mateusz,
Paul is correct - ST_Valid is not actually a defined OGC method, however the concept of validity is littered throughout
the specs.
Changing the wording is of no problem.  What would you recommend it be?  Perhaps something like:
"This method implements the concept of validity expressed in the OpenGIS Simple Features
Implementation Specification for SQL."
Cheers,
Kevin
Mateusz Loskot wrote:
> Thanks Paul!
> However, I'd (annoyingly) insist that the way how the reference to OGC
> spec is worded in the documentation of ST_IsValid is not precise
> and may be confusing. Especially when one compares to the similar note
> about ST_IsSimple.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
