[postgis-devel] [PostGIS] #259: ST_Distance geography throws an error with empty geographies
trac at osgeo.org
Tue Oct 6 04:09:11 PDT 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version:
Resolution: fixed | Keywords:
Comment (by mcayland):
Well the argument for NULL is fairly easy, given that the result is
unknown (i.e. can't be calculated) in this case, and the fact that SQL
Server 2008 returns the same answer is also a good indication that someone
else independently has followed the same logic. I'd be inclined to say
change both geometry and geography to return NULL in trunk but don't
backpatch.
ATB,
Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/259#comment:9>
