[postgis-devel] EMPTY
Chris Hodgson chodgson at refractions.net
Tue Oct 6 12:03:53 PDT 2009
EMPTY will get used because it is the result of some spatial operations,
ie. a empty intersection or difference. I think this is the primary
consideration for the handling of empty geometries, ie. that subsequent
chained operations or comparisons can operate on the an empty result in
a way that doesn't require special handling. eg. a query like this:
SELECT * FROM a JOIN b JOIN c WHERE st_intersects( st_intersection(
a.geom, b.geom ), c.geom );
I would dare say that geometry empty is more like zero, than null. The
SQL null value is different from the GEOMETRY EMPTY in that EMPTY is an
expected result of a successful, valid, operation, where null generally
is not, save for operations that are specifically designed to deal with
nulls.
Chris
Martin Davis wrote:
> One note on your semantics.  I think that
> ST_Intersects( empty, empty ) == FALSE
> The motivation for this is that EMPTY in the spatial realm is
> analogous to NULL in the SQL realm.  If there's nothing there, you
> can't determine anything about it.
> Although really I don't think any of this matters all that much,
> absent any clear use case for using EMPTY.
> Paul Ramsey wrote:
>> I've started a page on the semantics of empty. Please feel free to add
>> cases, clarify and discuss...
>> http://trac.osgeo.org/postgis/wiki/DevWikiEmptyGeometry
>> P.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
