[postgis-devel] EMPTY
Paragon Corporation lr at pcorp.us
Tue Oct 6 14:11:42 PDT 2009
Yap 0 on all counts.  Wow those Microsoft people are really smart.
 --geometry contains empty
  SELECT Geometry::STGeomFromText('POINT(1
2)',4326).STContains(Geometry::STGeomFromText('POLYGON EMPTY',4326))
	=> 0
--geometry within empty
2)',4326).STWithin(Geometry::STGeomFromText('POLYGON EMPTY',4326))
	 => 0
--empty contains geometry
 SELECT Geometry::STGeomFromText('POLYGON
EMPTY',4326).STContains(Geometry::STGeomFromText('POINT(1 2)',4326))
  => 0
 --empty within geometry
EMPTY',4326).STWithin(Geometry::STGeomFromText('POINT(1 2)',4326))
  => 0
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Chris
Hodgson
Sent: Tuesday, October 06, 2009 5:03 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] EMPTY
I agree with you Regina, and I bet SQL Server does too.
Chris
Paragon Corporation wrote:
> They should all be false.
> Isn't the first requirement of containment/contains be that the two
> geometries intersect -- so if we say empty can't intersect with
> anything including empty, how can anything possibly contain  it?
> Though have to pull out my sql server 2008 to see if it is in agreement.
> Thanks,
> Regina
> Paul Ramsey
> Sent: Tuesday, October 06, 2009 4:39 PM
> In the spirit of maintaining the geometry logical flow, what do you
> think of these ideas?
>  * ST_Contains(geometry, empty) == TRUE
>  * ST_Within(geometry, empty) == FALSE
>  * ST_Contains(empty, geometry) == FALSE
>  * ST_Within(empty, geometry) == TRUE
> What does SQL Server say?
> P
> On Tue, Oct 6, 2009 at 1:34 PM, Paul Ramsey
> <pramsey at cleverelephant.ca>
> wrote:
>> I'm going to change my intersection/disjoint answers to agree w/ SQL
>> Server. They are not bad, and they maintain the symmetry between
>> where intersection => ! disjoint.
>> P.
>> On Tue, Oct 6, 2009 at 12:45 PM, Chris Hodgson
>> <chodgson at refractions.net>
> wrote:
>>> I moved these and summarized the interesting results from SQL Server
>>> 2008 next to your original lines Paul.
>>> Note that SQL Server says that everything is disjoint from empty,
>>> including empty itself - whereas your original guesses were to
>>> return
> false.
>>> So far I think I like SQL Server's answers. Would be good to compare
>>> with oracle spatial too.
>>> Chris
>>> Paul Ramsey wrote:
>>>> Regina, could you move your SQL Server examples down to a big block
>>>> at the end, so the main part of the document is more readable? So
>>>> far I agree with SQL Server in all the examples! Those guys are
>>>> smart! :)
>>>> P
>>>> On Tue, Oct 6, 2009 at 12:12 PM, Paul Ramsey
>>>> wrote:
>>>>> On Tue, Oct 6, 2009 at 12:03 PM, Chris Hodgson
>>>>> wrote:
>>>>>> I would dare say that geometry empty is more like zero, than null.
>>>>> Bingo, there's a useful mental model. Wikify that!
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
