[postgis-devel] EMPTY
Martin Davis mbdavis at refractions.net
Tue Oct 6 14:25:24 PDT 2009
FALSE!!!!
Paul Ramsey wrote:
> OK, the uber question (Kevin can meditate over this one tonight):
> ST_Relate(geometry, empty)
> ST_Relate(empty, empty)
> On Tue, Oct 6, 2009 at 2:11 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> Yap 0 on all counts.  Wow those Microsoft people are really smart.
>>  --geometry contains empty
>>  SELECT Geometry::STGeomFromText('POINT(1
>> 2)',4326).STContains(Geometry::STGeomFromText('POLYGON EMPTY',4326))
>>        => 0
>> --geometry within empty
>> 2)',4326).STWithin(Geometry::STGeomFromText('POLYGON EMPTY',4326))
>>         => 0
>> --empty contains geometry
>>  SELECT Geometry::STGeomFromText('POLYGON
>> EMPTY',4326).STContains(Geometry::STGeomFromText('POINT(1 2)',4326))
>>  => 0
>>  --empty within geometry
>> EMPTY',4326).STWithin(Geometry::STGeomFromText('POINT(1 2)',4326))
>>  => 0
>> Thanks,
>> Regina
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net
>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Chris
>> Hodgson
>> Sent: Tuesday, October 06, 2009 5:03 PM
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] EMPTY
>> I agree with you Regina, and I bet SQL Server does too.
>> Chris
>> Paragon Corporation wrote:
>>> They should all be false.
>>> Isn't the first requirement of containment/contains be that the two
>>> geometries intersect -- so if we say empty can't intersect with
>>> anything including empty, how can anything possibly contain  it?
>>> Though have to pull out my sql server 2008 to see if it is in agreement.
>>> Thanks,
>>> Regina
>>> Paul Ramsey
>>> Sent: Tuesday, October 06, 2009 4:39 PM
>>> In the spirit of maintaining the geometry logical flow, what do you
>>> think of these ideas?
>>>  * ST_Contains(geometry, empty) == TRUE
>>>  * ST_Within(geometry, empty) == FALSE
>>>  * ST_Contains(empty, geometry) == FALSE
>>>  * ST_Within(empty, geometry) == TRUE
>>> What does SQL Server say?
>>> P
>>> On Tue, Oct 6, 2009 at 1:34 PM, Paul Ramsey
>>> <pramsey at cleverelephant.ca>
>>> wrote:
>>>> I'm going to change my intersection/disjoint answers to agree w/ SQL
>>>> Server. They are not bad, and they maintain the symmetry between
>>>> where intersection => ! disjoint.
>>>> P.
>>>> On Tue, Oct 6, 2009 at 12:45 PM, Chris Hodgson
>>>> <chodgson at refractions.net>
>>> wrote:
>>>>> I moved these and summarized the interesting results from SQL Server
>>>>> 2008 next to your original lines Paul.
>>>>> Note that SQL Server says that everything is disjoint from empty,
>>>>> including empty itself - whereas your original guesses were to
>>>>> return
>>> false.
>>>>> So far I think I like SQL Server's answers. Would be good to compare
>>>>> with oracle spatial too.
>>>>> Chris
>>>>> Paul Ramsey wrote:
>>>>>> Regina, could you move your SQL Server examples down to a big block
>>>>>> at the end, so the main part of the document is more readable? So
>>>>>> far I agree with SQL Server in all the examples! Those guys are
>>>>>> smart! :)
>>>>>> P
>>>>>> On Tue, Oct 6, 2009 at 12:12 PM, Paul Ramsey
>>>>>> wrote:
>>>>>>> On Tue, Oct 6, 2009 at 12:03 PM, Chris Hodgson
>>>>>>> wrote:
>>>>>>>> I would dare say that geometry empty is more like zero, than null.
>>>>>>> Bingo, there's a useful mental model. Wikify that!
>>>>>> _______________________________________________
>>>>>> postgis-devel mailing list
>>>>>> postgis-devel at postgis.refractions.net
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
