[postgis-devel] EMPTY
Paul Ramsey pramsey at cleverelephant.ca
Tue Oct 6 14:21:25 PDT 2009
Meaning FFFFFFFFF ? :)
On Tue, Oct 6, 2009 at 2:25 PM, Martin Davis <mbdavis at refractions.net> wrote:
> FALSE!!!!
> Paul Ramsey wrote:
>> OK, the uber question (Kevin can meditate over this one tonight):
>> ST_Relate(geometry, empty)
>> ST_Relate(empty, empty)
>> On Tue, Oct 6, 2009 at 2:11 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>> Yap 0 on all counts.  Wow those Microsoft people are really smart.
>>>  --geometry contains empty
>>>  SELECT Geometry::STGeomFromText('POINT(1
>>> 2)',4326).STContains(Geometry::STGeomFromText('POLYGON EMPTY',4326))
>>>       => 0
>>> --geometry within empty
>>> 2)',4326).STWithin(Geometry::STGeomFromText('POLYGON EMPTY',4326))
>>>        => 0
>>> --empty contains geometry
>>>  SELECT Geometry::STGeomFromText('POLYGON
>>> EMPTY',4326).STContains(Geometry::STGeomFromText('POINT(1 2)',4326))
>>>  => 0
>>>  --empty within geometry
>>> EMPTY',4326).STWithin(Geometry::STGeomFromText('POINT(1 2)',4326))
>>>  => 0
>>> Thanks,
>>> Regina
>>> -----Original Message-----
>>> From: postgis-devel-bounces at postgis.refractions.net
>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Chris
>>> Hodgson
>>> Sent: Tuesday, October 06, 2009 5:03 PM
>>> To: PostGIS Development Discussion
>>> Subject: Re: [postgis-devel] EMPTY
>>> I agree with you Regina, and I bet SQL Server does too.
>>> Chris
>>> Paragon Corporation wrote:
>>>> They should all be false.
>>>> Isn't the first requirement of containment/contains be that the two
>>>> geometries intersect -- so if we say empty can't intersect with
>>>> anything including empty, how can anything possibly contain  it?
>>>> Though have to pull out my sql server 2008 to see if it is in agreement.
>>>> Thanks,
>>>> Regina
>>>> Paul Ramsey
>>>> Sent: Tuesday, October 06, 2009 4:39 PM
>>>> In the spirit of maintaining the geometry logical flow, what do you
>>>> think of these ideas?
>>>>  * ST_Contains(geometry, empty) == TRUE
>>>>  * ST_Within(geometry, empty) == FALSE
>>>>  * ST_Contains(empty, geometry) == FALSE
>>>>  * ST_Within(empty, geometry) == TRUE
>>>> What does SQL Server say?
>>>> P
>>>> On Tue, Oct 6, 2009 at 1:34 PM, Paul Ramsey
>>>> <pramsey at cleverelephant.ca>
>>>> wrote:
>>>>> I'm going to change my intersection/disjoint answers to agree w/ SQL
>>>>> Server. They are not bad, and they maintain the symmetry between
>>>>> where intersection => ! disjoint.
>>>>> P.
>>>>> On Tue, Oct 6, 2009 at 12:45 PM, Chris Hodgson
>>>>> <chodgson at refractions.net>
>>>> wrote:
>>>>>> I moved these and summarized the interesting results from SQL Server
>>>>>> 2008 next to your original lines Paul.
>>>>>> Note that SQL Server says that everything is disjoint from empty,
>>>>>> including empty itself - whereas your original guesses were to
>>>>>> return
>>>> false.
>>>>>> So far I think I like SQL Server's answers. Would be good to compare
>>>>>> with oracle spatial too.
>>>>>> Chris
>>>>>> Paul Ramsey wrote:
>>>>>>> Regina, could you move your SQL Server examples down to a big block
>>>>>>> at the end, so the main part of the document is more readable? So
>>>>>>> far I agree with SQL Server in all the examples! Those guys are
>>>>>>> smart! :)
>>>>>>> P
>>>>>>> On Tue, Oct 6, 2009 at 12:12 PM, Paul Ramsey
>>>>>>> wrote:
>>>>>>>> On Tue, Oct 6, 2009 at 12:03 PM, Chris Hodgson
>>>>>>>> wrote:
>>>>>>>>> I would dare say that geometry empty is more like zero, than null.
>>>>>>>> Bingo, there's a useful mental model. Wikify that!
>>>>>>> _______________________________________________
>>>>>>> postgis-devel mailing list
>>>>>>> postgis-devel at postgis.refractions.net
>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
