[postgis-devel] EMPTY
Martin Davis mbdavis at refractions.net
Wed Oct 7 08:44:49 PDT 2009
It would be easy to allow ST_Relate to accept both dotted and undotted
notation.  It can just strip the dots out, since they are syntactic only.
Paragon Corporation wrote:
> Martin,
> As much as I prefer FFF.FFF.FFF for presentation.  I think it would be
> confusing since the more OGC compliant ST_Relate expects FFFFFFFFF for
> input.  So having the input of one function not be the output of another to
> me is even more confusing an annoying.
> Also I tested this in SQL Server 2008 and it returns 0.  So I take it SQL
> Serve disagrees?
> SELECT Geometry::STGeomFromText('POLYGON
> EMPTY',4326).STRelate(Geometry::STGeomFromText('POLYGON EMPTY',4326),
> 'FFFFFFFFF') => 0
> For PostGIS the operation is unsupported for geometry collections I guess
> because GEOS doesn't support it so can't compare.
> What is interesting is that this resolves to 1 and I would have expected 0?
> EMPTY',4326).STEquals(Geometry::STGeomFromText('POLYGON EMPTY',4326))  => 1
> Which seems puzzling to me because I thought equality requires intersection
> by OGC standards.  If that's the case -- SQL Server has violated its model
> because
> 'T*F**FFF*') => 0 (the intersection matrix for equality)
> Or they are defining STEquals in a way I am unfamiliar with. Maybe their
> STEquals is binary equality.
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Martin
> Davis
> Sent: Tuesday, October 06, 2009 5:31 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] EMPTY
> Yes, I replied too soon - after I realized that ST_relate returns the
> matrix,not a boolean result.
> But yes, I think FFFFFFFFF is the most reasonable return value.
> BTW, I'm thinking of changing JTS so that it returns a more readable format
> for the pattern - eg FFF.FFF.FFF  (recognized where I got that idea?)
> BTW2, the PG doc for ST_relate looks a little confusing to me.  It lists the
> ST_relate methods in the order (2 args => text, 3 args ==> boolean), but
> then goes on to say "Version 1 returns BOOLEAN....)
> Paul Ramsey wrote:
>> Meaning FFFFFFFFF ? :)
>> On Tue, Oct 6, 2009 at 2:25 PM, Martin Davis <mbdavis at refractions.net>
> wrote:
>>> FALSE!!!!
>>> Paul Ramsey wrote:
>>>> OK, the uber question (Kevin can meditate over this one tonight):
>>>> ST_Relate(geometry, empty)
>>>> ST_Relate(empty, empty)
>>>> On Tue, Oct 6, 2009 at 2:11 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>>>> Yap 0 on all counts.  Wow those Microsoft people are really smart.
>>>>>  --geometry contains empty
>>>>>  SELECT Geometry::STGeomFromText('POINT(1
>>>>> 2)',4326).STContains(Geometry::STGeomFromText('POLYGON EMPTY',4326))
>>>>>       => 0
>>>>> --geometry within empty
>>>>> 2)',4326).STWithin(Geometry::STGeomFromText('POLYGON EMPTY',4326))
>>>>>        => 0
>>>>> --empty contains geometry
>>>>> EMPTY',4326).STContains(Geometry::STGeomFromText('POINT(1
>>>>> 2)',4326))  => 0
>>>>>  --empty within geometry
>>>>> EMPTY',4326).STWithin(Geometry::STGeomFromText('POINT(1 2)',4326))
>>>>> => 0
>>>>> Thanks,
>>>>> Regina
>>>>> Chris Hodgson
>>>>> Sent: Tuesday, October 06, 2009 5:03 PM
>>>>> I agree with you Regina, and I bet SQL Server does too.
>>>>> Chris
>>>>>> They should all be false.
>>>>>> Isn't the first requirement of containment/contains be that the
>>>>>> two geometries intersect -- so if we say empty can't intersect
>>>>>> with anything including empty, how can anything possibly contain  it?
>>>>>> Though have to pull out my sql server 2008 to see if it is in
> agreement.
>>>>>> Thanks,
>>>>>> Regina
>>>>>> Of Paul Ramsey
>>>>>> Sent: Tuesday, October 06, 2009 4:39 PM
>>>>>> In the spirit of maintaining the geometry logical flow, what do
>>>>>> you think of these ideas?
>>>>>>  * ST_Contains(geometry, empty) == TRUE
>>>>>>  * ST_Within(geometry, empty) == FALSE
>>>>>>  * ST_Contains(empty, geometry) == FALSE
>>>>>>  * ST_Within(empty, geometry) == TRUE
>>>>>> What does SQL Server say?
>>>>>> P
>>>>>> On Tue, Oct 6, 2009 at 1:34 PM, Paul Ramsey
>>>>>> <pramsey at cleverelephant.ca>
>>>>>> wrote:
>>>>>>> I'm going to change my intersection/disjoint answers to agree w/
>>>>>>> SQL Server. They are not bad, and they maintain the symmetry
>>>>>>> between where intersection => ! disjoint.
>>>>>>> P.
>>>>>>> On Tue, Oct 6, 2009 at 12:45 PM, Chris Hodgson
>>>>>>> <chodgson at refractions.net>
>>>>>> wrote:
>>>>>>>> I moved these and summarized the interesting results from SQL
>>>>>>>> Server
>>>>>>>> 2008 next to your original lines Paul.
>>>>>>>> Note that SQL Server says that everything is disjoint from
>>>>>>>> empty, including empty itself - whereas your original guesses
>>>>>>>> were to return
>>>>>> false.
>>>>>>>> So far I think I like SQL Server's answers. Would be good to
>>>>>>>> compare with oracle spatial too.
>>>>>>>> Chris
>>>>>>>> Paul Ramsey wrote:
>>>>>>>>> Regina, could you move your SQL Server examples down to a big
>>>>>>>>> block at the end, so the main part of the document is more
>>>>>>>>> readable? So far I agree with SQL Server in all the examples!
>>>>>>>>> Those guys are smart! :)
>>>>>>>>> P
>>>>>>>>> On Tue, Oct 6, 2009 at 12:12 PM, Paul Ramsey
>>>>>>>>> wrote:
>>>>>>>>>> On Tue, Oct 6, 2009 at 12:03 PM, Chris Hodgson
>>>>>>>>>> wrote:
>>>>>>>>>>> I would dare say that geometry empty is more like zero, than
> null.
>>>>>>>>>> Bingo, there's a useful mental model. Wikify that!
>>>>>>>>> _______________________________________________
>>>>>>>>> postgis-devel mailing list
>>>>>>>>> postgis-devel at postgis.refractions.net
>>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>> Martin Davis
>>> Senior Technical Architect
>>> Refractions Research, Inc.
>>> (250) 383-3022
> Martin Davis
> (250) 383-3022
Martin Davis
(250) 383-3022
