[postgis-devel] [PostGIS] #264: CUnit geography suite failures
PostGIS trac at osgeo.org
Sun Oct 11 18:34:03 PDT 2009
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  postgis 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by robe):
 If this is GCC related -- I wonder if its a similar issue as #119
 And Mark's note about:
 http://fedoraproject.org/wiki/Security/Features#Compile_Time_Buffer_Checks_.28FORTIFY_SOURCE.29
 That would explain why I was picking up some failures in the CUnit that
 you were missing.  Which GCC are you running Paul?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/264#comment:2>
