[postgis-devel] fix for memory leaks in shp2pgsql.c
Dave Fuhry
dfuhry at gmail.com
Tue Oct 13 16:11:08 PDT 2009
Paul,
1.4.0.
I originally hit the problem on 1.3.x, then patched 1.4.0, which
I'm /pretty/ sure was exhibiting the problem.
It was easy to see in `top` that shp2pgsql was gorging on memory as
execution continued, and the leak locations were revealed fairly
clearly in `valgrind --leak-check=full`. This work is all against
polygons; my impression is that loading of points or linestrings is
unaffected.
-Dave
On Tue, Oct 13, 2009 at 5:32 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Huh, what version is this against? I thought I had cleaned those out.
> P.
> On Tue, Oct 13, 2009 at 2:21 PM, Dave Fuhry <dfuhry at gmail.com> wrote:
>> This patch fixes memory leaks in shp2pgsql.c.
>> Previously, loading a 1.5GB shapefile was running a 4GB machine out of memory.
>> -Dave
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
