[postgis-devel] [PostGIS] #269: Geometry -> Geography autocast should be explicit
PostGIS trac at osgeo.org
Thu Oct 15 07:27:21 PDT 2009
  Reporter:  mcayland  |       Owner:  pramsey
      Type:  defect    |      Status:  reopened
  Priority:  medium    |   Milestone:  postgis 1.5.0
 Component:  postgis   |     Version:
Resolution:            |    Keywords:
Changes (by robe):
  * status:  closed => reopened
  * resolution:  invalid =>
  * summary:  Geometry -> Geography autocast causes && operator query to
              fail => Geometry -> Geography autocast should
              be explicit
Old description:
> This is bad:
> trunk=# explain analyze select count(*) from cities where the_geog &&
> ST_SetSRID(ST_GeographyFromText('POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))'),
> 4326);
> ERROR:  operator is not unique: geography && geometry
> LINE 1: ...nalyze select count(*) from cities where the_geog &&
> ST_SetS...
New description:
 Changed subject:
 We really shouldn't be allowing people to use functions designated for
 geometry with geography data type without forcing them to explicitly cast
 to geometry.
 This is bad:
 4326);
 LINE 1: ...nalyze select count(*) from cities where the_geog && ST_SetS...
Comment:
 Ah okay that's what you are complaining about.  I'm in full agreement with
 you on this one then.  I'm going to change the subject line to be clearer
 and reopen the ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/269#comment:3>
